Discuss Over 3 mins to get hot water in kitchen - is this normal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The builder.
I believe the plumber designed the heating and hot water system as he is the most qualified person to do this - not 100% sure but it does not make sense for the builder to do it.
I said I wanted a boiler and a separate hot water cylinder due to the supply issue that I had with my combi. From my research I believe that combi-boilers are designed for flats rather than three/four storey houses. I said I wanted a Vaillant boiler as I hear they are one of the best.
He is aware and sticking by with what the plumber has said.
I have called Vaillant and they think it is to with the design of the pipework. They said that the fact that I am getting hot water means that the boiler is working.
It won't be a problem with the boiler, it will be either a very badly designed pipe layout or fault.
Either way, it's the builders responsibility to get it fixed if you're paying him and he's paying the plumber.
I've said it before, and I'll say it once more, get a decent plumber in to look at this!
I will do that. Could you recommend a decent plumber? Please PM me if you prefer not to post their details.
Thank you so much!
Give Mak a call on:
07899747777 his rates are £90 ph plus vat and I would expect him to find what's wrong in less time than it takes the kettle to boil.
Reply to Over 3 mins to get hot water in kitchen - is this normal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
