- Messages
- 710
hello i understand the combination of a pipe stat and a frost stat working together which makes sense.but can some one explain why can you not just a have a frost stat on its own? if it was a external boiler with a frost stat inside the boiler when the temperature get below 5 the boiler will fire up.then the surround temperature inside the boiler would get above 5 and would then turn the boiler off?
thanks
thanks
