Discuss low limit stat combined with a frost stat advice... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hello i understand the combination of a pipe stat and a frost stat working together which makes sense.but can some one explain why can you not just a have a frost stat on its own? if it was a external boiler with a frost stat inside the boiler when the temperature get below 5 the boiler will fire up.then the surround temperature inside the boiler would get above 5 and would then turn the boiler off?
thanks
But if you have a pipe stat on return it will shut off quicker. All about energy efficiency. Would take a lot longer to warm the space.
even if the frost stat was inside the boiler casing? i guess with the outside temperature and the boiler temperature would be average temperature and like you said it would take ages to switch off. cheers
hi scott i went to a service a boiler on friday with my boss and there was a frost stat and pipe stat on the return pipe.
i scott i take it the reason why you don't fit a frost stat inside the boiler is because it want be able to detect a true ambient air temperature?
it was a external oil boiler. why did scott say you don't fit frost stat inside boilers?
I thought you were talking about a wall hung boiler in a garage or loft :aureola:
best practise for future installation when fitting a external boiler is to fit a pipe stat and frost stat together?
what would be the problem if you were to fit a frost stat inside the boiler if it were inside the loft and was wall hang? what would the problem be?
In a loft, garage or shed then frost stat on the wall, on a block of wood, adjacent the boiler.
i have come across a sparky installation were a frost stat was fitted on the outside of the boiler house and no pipe stat, owner was winging the boiler was on all night at times and using a lot of oil :)
Reply to low limit stat combined with a frost stat advice... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
New built home. Has a combi on a 2 heating zones. The issue boiler located inside garage has a frost stat and a status ct100 pipe stat. The boiler...
I would like some guidance regarding the Worcester CDi 29 Classic boiler. According to the manual it has a holiday mode and frost protection mode...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night...
Hi all, My boiler was kind of new & installed last year July, I know there's build-in frost protection. Also, there's an old external frost...
After being woken up a few times by clicking pipework when heating not on looked at setup in boilerhouse. Trying to figure out why there are 2...
