Discuss Triton shower heater kettling query in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Ill do the temperature difference Chuck also check flow rate and physical water pressure. Note we have a TW10i on the same water main with no issues.
The 3 phase is not full 3 phase, only a single phase is live as they havent upgraded the tranformer yet. We are PME for the earth. Ive Fluke multi meter.
If I turn the shower temperature down the kettling decreases. Cold water flow, no kettling.
If the above is a actual shower then a thermal cut out (TCO) will trip the power at 48C if the flow rate is too low or the power too high and the water will then run hot & cold, if the temperature reaches a still higher temperature then the TCO will trip and won't reset and has to be renewed, if the temperature is constant looks like something in the water.
Yes has been tested I have a Metro RCD tester with croc clips in this case. It passes and disconnects, plus phase is correct.
Water temperature is constant.
We are in a software area. If it was water related I think the Triton TW 10i on the same water main would have shown issues too, it hasnt.
Did you ever measure the actual flow rate?
IIRC, the T100XR has a water filter on its inlet. This needs to be cleaned periodically. When was this last done?
A flow test may show up something in view of the above.
Don't know what the shower output is, have done a few calcs based on my mains temp of 8C
KW/showertempdegC/flowrate LPM
8.5/40/3.8
8.5/45/3.3
9.0/40/4.0
9.0/45/3.5
9.5/40/4.3
9.5/45/3.7
Reply to Triton shower heater kettling query in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Ah, the joys of older home ownership (1974). We thought our major plumbing issues were dealt with when we got rid of our orangeburg sewer line and...
2K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
Hi, this is my first post, it might be a bit long because im trying to put all the info which could be relevant but i'll try to avoid waffling on...
3K
  • Locked
ok had a new unvented tank fitted and system changed from gravity to fully pumped. initially the plumber connected to the original gravity...
3K
Dotty
  • Locked
I MOVED INTO MY NEW HOME 3YRS AGO AND IN THE BATHROOM WAS A TRITON T80SI. THIS WAS EXISTING AND AFTER A FEW MONTHS OF MOVING IN THE SHOWER BURNT...
7K
PlumbBobBob
