Discuss stain remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
can anyone suggest a cleaner for removing the odd mark on carpets caused be the occasional dropped fire coal / flux brush/soot etc . had to give a customer a discount as a coal rolled onto the carpet and marked it.
Tend to rub the mark with my foot (boots off) and hope my every day clean socks do the trick - never use water. If you rub it around a while it can sort of blend into the rest of the carpet - at least until the chqs cleared !
centralheatking
Leak detector fluid is brilliant for this, cover the stain in it and rub like mad. It's brilliant. The best one I have used is from parts centre and comes In an aerosol can. It removes anything. Even black sludge from rads. It's amazing.
I take it that you like it then? :teeth_smile:
How on earth did you find this out !
keep a selection of company logoed hearth rugs, turn a potential problem into a marketing opportunity !!:disguise:
On a more serious note 1001 sprays is my panacea of choice.
Reply to stain remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
