Discuss stain remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
buckley plumb
can anyone suggest a cleaner for removing the odd mark on carpets caused be the occasional dropped fire coal / flux brush/soot etc . had to give a customer a discount as a coal rolled onto the carpet and marked it.
Tend to rub the mark with my foot (boots off) and hope my every day clean socks do the trick - never use water. If you rub it around a while it can sort of blend into the rest of the carpet - at least until the chqs cleared !
centralheatking
Leak detector fluid is brilliant for this, cover the stain in it and rub like mad. It's brilliant. The best one I have used is from parts centre and comes In an aerosol can. It removes anything. Even black sludge from rads. It's amazing.
I take it that you like it then? :teeth_smile:
How on earth did you find this out !
keep a selection of company logoed hearth rugs, turn a potential problem into a marketing opportunity !!:disguise:
On a more serious note 1001 sprays is my panacea of choice.
Reply to stain remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
I wonder if anyone has any thoughts? Combi Logic 30 Boiler - constant pressure loss - no obvious leaking. Few years ago we got an error code...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
