Discuss Help glow worm Hideaway 80b bf stopped working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fra
My glow worm hideaway 80b bf boiler (14 years old) has suddenly stopped working. It was heating the radiators up fine one minute then suddenly stopped. Electrics are fine - timer on as normal, and light comes on. Pilot is on but the boiler does not fire up when i switch the 'boost' on. Pump seems to be ok. A few weeks before some of the radiators were not heating up as much as usual. Can anyone help? Thanks
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Help glow worm Hideaway 80b bf stopped working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a...
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am...
10 months ago had a new Glow-Worm gas boiler installed in our bungalow. It failed nearly a month ago when a gasket internally in the HW feed cct...
