Discuss Bristan easy fit taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've fitted two or three previously that I remember. None for at least 4 months with no problems so far.
But I did fit one this morning but I don't think it was Bristan. But exactly same set up except it had one of those horrible fixing kits that are like a sharp ended pivoting bar instead of the horse-shoe-shaped plate and rubber washer. Customer supplied it. No idea what it was. I will contact them and warn them, can even link them to this thread.
I won't fit another.
I spoke at length to Bristan technical today, they said if the base plate is 180 degrees out then the grub screws don't land in the grooves but it still fits together and will hold for a time.
Later versions appartantly make it idiot proof by having grooves on the other side but I need to see this for myself.
I have fitted 21 Easyfit taps since June 2015 of which 4 have blown off so far, one after 8 months, another after 11 months and another after 13 months. Out of 6 Monzas 3 have failed, and out of 8 Echos 1 has failed. I have also spoken to an installer who has had lots of Manhattans blow off. I have just posted a video to explain the problem to all 21 of my customers and have emailed them my concerns. I thought it was 3 that had blown off, but one of them emailed me right back saying his kitchen was flooded 6 months ago and his insurance plumber had replaced the tap. I was surprised he hadn't called me. Anyway, here's the video. I hope it's helpful:
https://youtu.be/chTGvh-Rsas
Don't see what the problem is tbh just use some loctite thread lock on the grub screws like I do haven't had one pop off
I know you shouldn't have to but it's the days where manufacturers don't think ahead / take responsibility
I was of the same thinking as you Hamish that by supplying my customers with Bristan taps I was fitting a quality product but unfortunately this has not proved to be the case.
My first issues was the ceramic cartridge dripping (not the easy fit range) after about a year, they did send replacement free but said this was a one off, of course I couldn't charge my customer for my time to replace them, then the same problem occurred approximately a year later with the replacement cartridges, my customer requested a different brand which they were willing to pay for but I agreed to fit FOC as I had recommended and supplied the Bristan taps.
In between the previous episodes I fitted some easy fit kitchen mono block taps , which to be honest was anything but easy fit, about three months after that got a phone call from someone that had just had a Easy fit kitchen tap go in to orbit and totally flood her house obviously she and I assumed the plumber that fitted them had not done so properly, but I soon saw the reason why, the grub screws had loosened, so refitted and put a bit of thread lock on but was still worried it could happen again and explained my concern, No charge.
I then contacted my customer where I fitted the easyfit tap to check it remove grub screws and thread lock them, no charge obviously.
Then came on this forum and discovered others had the issues
Its all very well manufacturers sending out replacement parts but why do we always have to swallow the labour costs the least they could do is supply us with a substantial discount voucher on future purchases, not that I would be likely to use Bristan again. Or better still just a voucher to buy something for yourself
It's true that loctite thread lock might be an effective solution, but thinking back to their promotional video with Roger Bisby, if Bristan's design engineers were really so smart when they came up with the Easyfit design, they might have thought about including a tube of that in the box of every Easyfit tap. And Bristan must surely have been aware of this thread since it started back in October last year. So why has nearly a year gone by and they haven't thought to send out one of their engineers to check each registered product and apply a touch of thread lock for safety's sake? Or even to contact the installers and ask them to do so. What amazes me is that Bristan are still sailing full steam ahead with the Good Ship Easyfit, while it is sinking beneath them. The Easyfit concept is flawed for several reasons. Firstly, the initial install of an Easyfit tap is not really any easier than installing a normal tap with horse-shoe and backnut. It is only on the subsequent replacement of the Easyfit tap, 5 to 10 years down the line, that the Easyfit design is a real timesaver. Secondly, the benefit is a 10 minute replacement in several years' time install of a 1 hour job. A 50 minute saving every 5 to 10 years is an almost negligible benefit. Thirdly, the Easyfit concept adds an additional element of risk that wasn't there before, and the risk of a blow off is so serious that it isn't worth the added risk, however much they try to tinker with their design. Fourthly, if you replace the tap in 5 years' time but retain the existing base, the base may by then have deteriorated in various ways, such as the rubber o-rings perishing, the isolating valves dripping if you turn them, or the flexible pipe tails may have rusted due to condensation and eventually burst if they get too old and rusty. It would be better to have a new base at the same time as the new tap. But in that case, the Easyfit concept is redundant because you then need to access under the sink to change the flexis and isolators.
As a plumber, the last thing you want is to flood a customer's house. At this point, I don't care what modifications they make to the Easyfit design - I wouldn't touch another Easyfit tap with a barge pole.
If you are concerned about Easyfit taps that you have already installed, call Bristan's customer services and discuss my YouTube video and this thread with them. Ask them to provide you with a case reference number that you can use when you write to your customers and alert them to the problem and the risk that their homes may be flooded. If your customers then call Bristan and quote your case reference number, they will be immediately identified as your customer. They can request that Bristan replace their tap under guarantee because the design is faulty. If your customers receive an unsatisfactory response, the ball is then back in your court to contact Bristan and get on their case.
Bristan have been behaving as though they can deny there is a problem and hoping that by doing so the problem will just go away. It's your job to remind them the problem won't go away as long as you have customers out there whose homes are at risk of flooding from an Easyfit tap.
It won't be long before they have no choice but to issue a product recall. But for the sake of your customers and your reputation, I don't suggest you sit back and wait for that to happen.
Unless you want to go round all your Easyfit customers with a tube of loctite...
Phfffff.
That was a bit of a read Hamish.
Me with one eye due to the other one calling it a night about half an hour ago.
1. Roger Bisby is a prik
2. Bristain are playing the numbers game
I had a 3 and 4 but rubbed it out ;)
If you buy from a merchant rather than toolfix you won't/don't need to swallow the labour. It is an easy process to contra them and they will cave in.
Are you saying that CPS, Graham, Plumbase, Plumb Centre will reimburse my labour costs if they provide me with a faulty product?
I definitely wont be fitting any Bristan products unless my customer supplies them excluding easy fit taps I would recommend
returning for refund
i would say they wouldnt as they would say contact manufacturer unless one of there branded products
When it comes to reimbursement for your labour, I think there are just times when you have to take that on the chin. I'm not seeking reimbursement for the three return visits I made when the taps blew off. And I don't want to cheese off my local Plumb Center guys by expecting them to pay, because I rely on them for all my supplies and I want to maintain a good relationship with them. But there's a limit. I could have ordered 21 replacement non-Easyfit taps and gone round all my customers and said 'Please can I give you a free replacement because the Bristan one is dodgy'. That would have cost me an hour's labour plus a new tap per customer, and if you multiply that 21 times thats a lot of money. Given that Bristan give a 5 year guarantee, that's not a cost I felt I should swallow. Instead I have had to go through all my Plumb Center invoices to count all the taps I've bought and then go through all my customer invoices to account for every tap and where it was fitted. That in itself took quite a bit of time. I then spent all of Thursday making my video and then emailing all 21 customers with a CC to Bristan's customer services. When Bristan's CEO watches my video, I doubt he's going to say, 'Let's reimburse Hamish for his time'!
Might be worth bringing it to the attention of "Which" they like things like that or "Watchdog" or similar, Wonder if you wrote a letter to one of the plumbing or gas publications they would actually print it, very doubtful which would just proves they really don't care about us just their advertising income
I was in Grahams today, which isn't my normal supplier, but they keep a stock of Denzo tape which I needed. I noticed their display of Easyfit taps and I mentioned that I had had big problems with them. They didn't seem surprised. They said they don't sell many, as it is fairly well known within the trade that they are risky. That surprised me. If plumbers are aware that there's a problem, why aren't more plumbers making a noise about it?
I also returned my remaining stock of Easyfit taps to Plumb Center for a refund and spoke to the Exeter manager. I showed him my video and he was quite shocked and obviously concerned about all the other Easyfit taps he has sold. I don't think he'll be selling any more for a while.
Sometimes when you know something, you also have a responsibility to speak out about what you know. If you are a plumber who reads this thread and you're aware of the problem, why not share my video on your Facebook page. The link is:
And next time you are in your plumbing merchants, show it to them on your phone. It is also very easy to find it you go to YouTube and search for 'Hamish the Plumber'. Then look for the one with me holding up a Bristan Echo box.
Just happened on this thread and had a bit of a shock because I have one of these taps in my kitchen. I ordered the tap on line can't remember where from to replace an existing Bristan. I ordered a conventional tap but this was sent, I presume by mistake. Needless to say I immediately went and checked it. The grub screws are as tight as the day I fitted the tap and could not be tightened further.
As others have said I don't really see the need for this type of fitting but I have viewed the video.
What I can't understand is how the grub screws can loosen themselves.
Good question, about how the grub screws can loosen themselves. I never anticipated that would happen until taps actually started blowing off. I don't have a definite answer, but I guess that every time the tap is turned on and off, or the spout turned from side to side, there is a small but repetitive stress placed on the grub screws. It's strange how things do loosen over time with small repetitive stress or vibrations. I image that a tall tap like an echo suffers more stress due to greater leverage than a lower one like the cinnamon. It might be that echos start blowing after about a year and that cinnamons will last longer. But the grub screws ought to stay tight for the life of the tap, say 10 years or even longer. So to be working loose in less than a year is really rubbish.
I've just been re-looking through this thread from the beginning. I was shocked to see that ed209 started it way back in January 2015, and was talking to Bristan about it on 20 January 2015. So Bristan have known about this problem for ages. On 1 October 2015, CROFT was talking to Bristan about them paying for damages to a customer's property. On 5 October 2015 JACKY spoke to Bristan and they admitted problems with Easyfit (privately of course). And yet, when I spoke to them on 2 August 2016 they had the gall to tell me that in all the cases they had investigated, it was due to installer error! I recorded the conversation - it is tempting to post the mp3 online!
Reply to Bristan easy fit taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
