Billy Bob Bob
our second van the trasheds off the road again a bolt on the gear selectors come loose,punched a hole through the gear box, basically the transits got 2 cables going to the gear selector on top of the box this selector seizes regularly and i have to remove it to free it up this time the old man was going to a job and lost all his gears i had to tow him back in the expert the bolt on the internal part of the selector had come loose and smashed its way through the casing however if this was at motorway speeds it would have caused the gear box to seize which in turn would snap the crank on the engine so if you own a transit and dont check this problem out you could lose your gear box plus the engine,luckily i got it to a garage to get the gear box removed to weld the housing but it still cost 200 quid you have been warned fellas
