Discuss which grips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
which grips do people use to prevent scratching TRV's or chrome fittings?
I usually use a towel, but grips go through these
Adjustable spanner not grips or pump pliers. Preferably bahco.
until some idiot has used push fit fittings with straight rad valves and valve keeps moving, then you have to put grips on valve
Ah see what you mean, I don't worry about it.
Reply to which grips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
