Discuss which grips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
which grips do people use to prevent scratching TRV's or chrome fittings?
I usually use a towel, but grips go through these
Adjustable spanner not grips or pump pliers. Preferably bahco.
until some idiot has used push fit fittings with straight rad valves and valve keeps moving, then you have to put grips on valve
Ah see what you mean, I don't worry about it.
Reply to which grips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
