Discuss which fitting? radiator 15mm pipe to central heating valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
HI!
i am a new member and only a DIY'er
i have had to replace a radiator with a smaller one
i need to extend the outlet of the radiator by 6" using
15mm copper pipe...what fitting do i use to connect
the pipe to the system valve (which has the original radiator fitting connected )
regards
any pics of the valve you need to go onto
upload a file right of post reply
yes but how do i upload it
best way would be drain down and either adjust the pipework or install a new valve
eg
https://www.NoLinkingToThis/p/drayton-07-05-900sx-white-chrome-angled-lockshield/7877g
https://www.NoLinkingToThis/p/compression-adapting-male-coupler-15mm-x/67110#_=p
and use a piece of 15mm chrome pipe between the rad and valve
if you dont want to drain down
https://www.NoLinkingToThis/p/compression-adapting-female-coupler-15mm-x/76567
and a piece of 15mm chrome
eg
thanks very much will check it out♪♪
Reply to which fitting? radiator 15mm pipe to central heating valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
