Discuss New part L 55 degrees flow? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Stumbled across this when researching heat pumps surely this can't be true for gas boilers? And un-enforceable..
So we have to oversize rads for this lower flow? The few point of natural gas is 54 degrees I believe. So a flow of 65 would be ok with a delta T of 11c.
A flow of 55 so return 35 ready for heat pumps eg no need to do any internal pipework alterations
Interesting if boiler controls in future simply won't be adjustable over 55degC. If there is no reg to actually fit new larger rads then if it's left set at 55degC at the end of a new boiler job then what's to stop the owner just turning it up a bit in the depths of winter? Oh yes - the gas bill!
So in the long term also fitting those bigger rads may be in the customer's interest? (Apart from many won't have the cash up front)
Hoping for a mild winter.
Cheers,
Roy (amateur)
No as boiler manufacturer are saying what about older installations they can’t lock 55
You misunderstand Roy, the boiler will only be set to 55 deg C where the system has been designed for this, in which case there would be no advantage to turning the boiler up a bit.
In reality this will be all new builds and most complete system replacements, but it won’t be possible in all cases so there is no way manufacturers will restrict to 55 in the foreseeable future ……
Reply to New part L 55 degrees flow? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
