Discuss New part L 55 degrees flow? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Anyone work on new builds and seen this come into effect?
Interesting if boiler controls in future simply won't be adjustable over 55degC.
You misunderstand Roy, the boiler will only be set to 55 deg C where the system has been designed for this, in which case there would be no advantage to turning the boiler up a bit.Interesting if boiler controls in future simply won't be adjustable over 55degC. If there is no reg to actually fit new larger rads then if it's left set at 55degC at the end of a new boiler job then what's to stop the owner just turning it up a bit in the depths of winter?
Reply to New part L 55 degrees flow? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
