Discuss Grips and adjustables in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have this for 15 and 22 compression fitting but the nuts are often different sizes. Carry as little as possible
I have that one but like you said fittings are often not standard enough. The same manu makes a pump valve nut spanner, its a beast but you only have to show it yo a pump valve and it lets go.
I've got a couple of them. My mates I work with call it ''The Irish Spanner''
I don't know what to say. Use right tool for right job. If you used footprints on chrome I would hit you. If you tried adjustables on iron I may hit you. If you used grips on a boiler I would hit u.
That's one way of teaching your apprentices :tounge_smile:
I've got my eye on some footprints but I use bahco adjustables (I actually don't like them) and stanley fatmax grips which I bought to replace a pair of Irwins I left at a custards house. I actually really like the fatmax grips, they're comfortable and have a push button to adjust the size which is handy when only have one free hand! I also have a rothenberger adjustables which aren't too bad.
Reply to Grips and adjustables in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
