Discuss Capping 8mm fire connections in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jay_1981
Everyone has their prefered method, just wondered what some of you use to cap ID fire connections (8mm) I'm only asking as I had a joyful time today tracking a pipe back to 15 to cap it when I forgot to replenish some fittings.
i use what we all use
silcon sealant,or plumbers mate,or a plug of potato, a wooden pencil whittled down. But if none of these are availiable you could turn of the restrictor elbow and put a blanking plug in it. the latter of course would leave us looking proffesional, god help us if that catches on!
lol, plug of potato, love it. just out of curiosity I have only been qualified for 5 years has it ever been permitted to crush and solder the pipe closed obviously i know it has never been permitted for as long as I have been in trade but i still do see legs of pipe isolated in this way (just quickly throw a proper cap on it) seems really ropey practice even by rogue standards.
Does anyone know where i can get suitable comp caps for 8mm
You will need a 1/4" bsp plug as apposed to a cap really, it will be much neater in the end of the restrictor elbow. Or a 1/4" bsp brass cap and remove the restrictor completely. It is not acceptable to squeeze the end of a pipe over and solder it as this is not a standard joint. Also remember that any dead leg of gas pipe must have a physical means of release or removal so that air can be purged from it.
Graham
www.plumbfixit.synthasite.com
Reply to Capping 8mm fire connections in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
  • Locked
right, i have a problem. let me quickly explain. i had been getting bad water hammer, and presumed it was caused by a old vertical peice of pipe...
9K
k13 wjd
K
C
  • Locked
Sorry about the title but with all the trainees about, I had to grab everyones attention and stand out somehow! I am looking for someone who...
8K
fuzzy
F
T
  • Locked
Morning everybody, I have the above boiler which had an ignition problem which has now been sorted out,may i add by all your help a big thank...
2K
T
  • Locked
Can anyone help me please . I have been asked to replace a leaking rad on the first floor landing of a house that has about 17 rads . The new...
tommy boy
T
O
  • Locked
lost a job for boiler and central heating install to some undercutting b*gger today. Rang to confirm start date to be informed other plumber on...
3K
davetheplumber
