Super Mario
- Messages
- 160
Im llooking for a new combi drill for around £150 what is the best at the moment?
Discuss Best combi drill at the moment? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
You'll need to spend more than £150 to get a Milwaukee.
That price, Bosch or makita. Wont come with great batteries for that price though
theres this millwaukee £209 but only 50nm not great?
Toolstation > Power Tools > 18v Drills > Milwaukee M18SET1A-421C C18PD Combi Drill
I daresay 50nm is the max torque setting, not the max drilling power.
remember having this convo with a rep.
i have the heavy duty milwaukee combi drill.
5 inch holesaw through a flat roof quite happily
Depends on the user :smile: I was brought up on brace and bit and rawlplug tool :wink:Brace and bit has a max torque of 500nm! Top speed 3m/s
It depends what you want to use it for. All cordlesses have limitations so buy the tool for what you intend to use it for. Btw if you are on a tight budget go fo a high ah nicad. Nicad is still a good battery tech, just a bit heavier than li-ion which also has its drawbacks.Im llooking for a new combi drill for around £150 what is the best at the moment?
There are not many cordlesses out there that could do this Metabo Power Tools BS 18 LTX QUICK PowerX3 800mm screw 18V Cordless Drill Driver BS18LTX - YouTubeMetabo have a chuck attachment for there top of the range cordless drills that triples its max torque i believe, id love to try one.
li-ion no good?
Li-ion is good, it's just in that price range you will get low amperage batteries. Like 1.3ah instead of the newest 4.0ah
I just showed you a bosch with a 4ah battery for less than £150 on plumbfix
I looked at that drill, but I just wasn't sure about hitachi, I've always bought bosch tools.Hitachi 18V Cordless Combi Drill with 2 x 4Ah Li-Ion Batteries: Amazon.co.uk: DIY & Tools
I went with this. Really impressed with the power and how long the batteries last.
- 2 x 4.0Ah Batteries weighing 0.64kgs each(33% Longer run time over previous battery).
- Variable speed control
- Extremely High Torque = 92Nm
- 13mm Metal Jacobs Chuck with ratcheting lock
- 2 Speed Gearbox
disregard every comment on here,and see if you can still get the Makita 458 rfe on amazon for £179 2 batts and a charger.was £333 plus vat last year.If you cannot kill yourself and donate your brain to medical science to combat stupidity
Reply to Best combi drill at the moment? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
