Discuss Ball Park Price Please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If anyone could give me a rough ball park cost for the following work that would be great. Had two very different quotes and wanted to see who is more realistic
Supply and replace 3 port valve head on cylinder
Supply and fit new cylinder thermostat
Rewire central heating controller to provide independent control of heating and hot water
Manual flush of 5 radiators
Thanks a lot
i would allow a day for the flush, and another day for the 3 port to an s plan system (hate 3 ports) and cylinder stat and wiring but depends what state the wirings in
dont you already have independent control of the system?
Too many variables mate and we shouldn’t really give quotes on the open forum as prices can vary massively around the country.
What make head?
Is there additional cost of you find that whole valve needs replacing?
Vented or unvented cylinder?
Is the current wiring a dogs dinner?
Is accessibility good?
Manual power flush?? Radiators off system and blasted through with hose in the garden or actual power flush with proper chemicals and flushing machine??
Was about to type earlier as above then got distracted with the kids yet again:rolleyes:. If he has quoted for the above why not do it all properly and change it to an s plan? Also about a day and a half/2 days. Dependent on the state of inside the rads and pipework. Some engineers logic confuses me.
Hi chaps and thanks a lot for taking the time to reply
Basically I can’t turn my heating on without turning on the hot water. Plumber thinks the valve head is stuck so will replace it, maybe even with a 2 port (can’t remember exactly what he said) and then rewire to get the independent control
Does that make sense?
The radiator flush is an attempt to get them
Working again as they are currently stone cold
how old is the pump?
Ps been quoted 280 and then 500 quid so big difference
Vented cylinder
Radiators flushed manually with hose
Good access and wiring not bad
Vented cylinder
mmm 280 is too cheap theres about 100 of parts so thats 140 either hes missed the flush or doing it all in half a day to three quarters
Rads at the mo don’t work and make a popping noise across the system
Only the ones nearest the boiler heat up
Will flushing em sort that?
dont know but doesnt sound like it all rads would be the same
normally ground floor have the more issue
You can’t turn your heating on without hot water,has this always been the case or something that’s recently happened? If you had independent control of hw & ch before then I can’t see the need for the rewire unless he’s changing it from a Y plan to an S plan.Are your radiators stone cold even when you put hw on like you said earlier to get Ch working ? Sounds to me like it’s one fault that needs fixing
It’s always been the case mate.
He’s had a go today, the new valve is on but the sparky didn’t turn up so not wired lol
Rads were really gungy inside but now the system is back on we have the same problem
Towel radiator next to cylinder red hot, next radiator quite hot then the rest really struggling to get hot at all
Also a popping sound from inside the ones that do work
System was drained and bled today too
I’m at a loss! Not paid him yet either
Could it be the pump? It’s an old one that was put on before the boiler was replaced in 2013. The boiler is not the problem it’s a wordester and is working well
:D pump
thought you said it was only 4 years old
Could you take few pictures of your set up,ideally airing cupboard/where your hw cylinder is thanks
*just to clarify,if you put CH only on does the boiler fire up an pump runs? If you put hw only on do your radiators heat up?
The 3port valve body looks new as to the actuator that’s on it...it looks mashed
The metallic rectangular box that’s on top of the brass body
The silver box on top. It looks like a cheap diverter valve.
Random question. You haven’t changed the timer recently have you?
The silver thing on top is new today
Flomasta or something
Sorry really thick again how do i change the timer?
Thanks a lot for all the replies i really appreciate it
I would do valves as well so full drain down. Check to see if it is spinning first.
Put it this way the pumps the same age as me :D
Think screwfix special
That looks new. When was it fitted? Also when you put the heating on by itself does the hot water light come on as well at the same time?
Ok. So excuse my bluntness but if that is the case. Then you should clearly be able to have the hot water and heating on separately. I have just read your first few posts again and you say that you have to have the water on to get heating. This would point to a faulty diverter valve. I have had new cheap diverter valves faulty straight out of the box. Did he go and get the valve or was it on his van. I would ask him how long it has been on the van also.
It's not wired so he can't tell atm
No bluntness at all mate, no worries
That new one replaced an old one that he thought was jammed or bust hence why I couldn’t get heating without the hot water being on
He put the new valve on today (flomasta) but couldn’t wire it up as his mate the sparky didn’t show unfortunately
Looking at what's been done I would be looking at using another Plumber, one who can do the wiring, (Simple wiring) what with your guys charge plus that of a sparks , get that pump & Valves replaced as well , Don't mind me asking what are you being charged for this ? and its still not working.
I haven’t paid him yet! Sad I won’t until it’s working
At the moment I have hot water but only two rads functioning (the two closest to the cylinder). The rest are mixture of cold and luke warm
Some fill pipes are scalding to touch others are cold
Think it’s a pump issue?
Just think you need to call someone in who knows what they are doing, this guy is a waste of time !
Reply to Ball Park Price Please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
