Discuss Ball Park Price Please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If anyone could give me a rough ball park cost for the following work that would be great. Had two very different quotes and wanted to see who is more realistic
Supply and replace 3 port valve head on cylinder
Supply and fit new cylinder thermostat
Rewire central heating controller to provide independent control of heating and hot water
Manual flush of 5 radiators
Thanks a lot
i would allow a day for the flush, and another day for the 3 port to an s plan system (hate 3 ports) and cylinder stat and wiring but depends what state the wirings in
dont you already have independent control of the system?
Too many variables mate and we shouldn’t really give quotes on the open forum as prices can vary massively around the country.
What make head?
Is there additional cost of you find that whole valve needs replacing?
Vented or unvented cylinder?
Is the current wiring a dogs dinner?
Is accessibility good?
Manual power flush?? Radiators off system and blasted through with hose in the garden or actual power flush with proper chemicals and flushing machine??
Was about to type earlier as above then got distracted with the kids yet again:rolleyes:. If he has quoted for the above why not do it all properly and change it to an s plan? Also about a day and a half/2 days. Dependent on the state of inside the rads and pipework. Some engineers logic confuses me.
Hi chaps and thanks a lot for taking the time to reply
Basically I can’t turn my heating on without turning on the hot water. Plumber thinks the valve head is stuck so will replace it, maybe even with a 2 port (can’t remember exactly what he said) and then rewire to get the independent control
Does that make sense?
The radiator flush is an attempt to get them
Working again as they are currently stone cold
how old is the pump?
Ps been quoted 280 and then 500 quid so big difference
Vented cylinder
Radiators flushed manually with hose
Good access and wiring not bad
Vented cylinder
mmm 280 is too cheap theres about 100 of parts so thats 140 either hes missed the flush or doing it all in half a day to three quarters
New posts
Reply to Ball Park Price Please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
