Discuss First Gas Safe Inspection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys,
Hoping some of you can help me out slightly as I’m bricking it at the minute. I am going to register for my own Gas safety registration soon and am really worried about the inspection.
I have always been under an employers registration and have never actually have a inspection of my own.
I don’t really know what to expect and am worried as I don’t actually have any jobs of my own to take them to so not even sure how I could be inspected as such?
Any pointers would be
Hi Guys,
cut off in his prime .... Perhaps it was nerves? :eek:
Hi Guys,
You’re worried about something you haven’t got yet. Chill out. Relax. Your first inspection can be a family member if needed.
your first meet is to get on the regester , I doubt if he will want to see any of your work , or at least thats how it used to be .
Lots of questions, concentrate on what he asks , and the most obvious one dont be a clever **** which I doubt you will , good luck .
When I had my 1st inspection after getting my own registration last year he came to my house 1st. Few questions and chit chat. Then I took him to 2 installations and in 1 I did a tightness test and the other I had to do a gas rate. He checked through my benchmark paperwork and left. He covered the Ipswich area. Not sure if they do things differently up and down the country. I had 3 months to gather work to show him.
Very informal, just chatted about where I’d worked and jobs i’d done, a few bits of tech talk and that was about it.
I got the feeling that I was being grilled, and as long as I said the right things in the right lingo, it was ok for him, never even got my tools out.
Let’s face it, I could teach my 6 y/o son to gas rate an appliance and do a tightness test, that’s the easy bit.
Just take it all in your stride pal. :)
There is nothing to worry about they understand that your nervous and really put you at ease.
When I had mine it was just chat a few questions that you should know then he watched me commission a boiler that I’d just installed
Yet many people get both wrong.
Ok thanks. Hopefully you re right!
Is he likely to ask me to do bits at my boiler where I live? It’s a Suprima and I’ve never done anything on older boilers, as usually just out new ones in. Will have to read up on it if so
You might be over thinking this a bit which is understandable but don't worry. Whoever comes will have been in your shoes. They are human just like you. The ones I met over the years have all been ex-engineers. If they can tell you are conscientious (and going off this post you probably are) they should be happy. If you are unsure of anything then ask the question. Good luck.
Well I at least try to be. You might be right about overthinking this as I am definitely a worrier when it comes to exams etc. I can panic about the simplest of things in an exam situation. I expect if he asks me to do a tightness test I’ll be shaking and dropping the test nipper cap etc.
Just wondered if there were any particular areas they will definitely ask. I assumed tightness testing, gas rating maybe clearances etc. I wasn’t sure on certain things like Se or U ducts were going to come in or ducts in series anything like that as it’s not stuff Ive done bar the classroom
It would be s good idea to know your way around your own appliances
They will also want to look at your paperwork, warning pads, FGA calibration
I cannot see them quizzing you on S + U duct installation to be honest. Those are things many of us don't come across that often.
The main things will be that you know the basic everyday safety checks e.g. Let-by, Tightness, Standing pressure, Working Pressure, Burner Pressure, Ventilation, flue termination, Gas Rates, Spillage testing (don't forget extract fans and interconnecting doors), Flue flow, ECV (Emergency Control Valve) position and labeling, Earthing/bonding etc etc.
If you test something make sure you test the test point/nipple with something like LDF or a sniffer if you have one (if you don't it won't matter for this) when you have finished. Check the anaconda joints and the thing itself with LDF (wipe it off after) or a sniffer. They are pre-governor so will be likely to have a higher pressure inside than the test pressure you use on the installation side, so will the ECV. I always test the joint pre-ECV with something too as that is definitely not tested during a tightness test. The Governor can lock up in some circumstances and any leak on the anaconda or ECV would fail to show a drop on the tightness test being carried out on the delivery side of the Governor (rare but seen it with my own eyes), that's another reason to test the anaconda.
If he is going to take you to see work, have your general everyday kit ready. e.g. LDF (Leak Detection Fluid), manometer and tube, stop watch (phone will do nowadays), FGA (calibrated), calculator (phone will do nowadays), Smoke bombs, Closure plate/duct tape, some caps/plugs/stop ends, fittings etc, warning notice pads, your book of words.
I hope this helps ease the worry. He is not coming to trick you in any way. If there are doubts/questions in your mind I'm sure they would prefer that you asked. It is up to them whether they release you into the world to work on Gas so they will want to see that if you don't know the answer, you'll find out!!
Any questions over anything I mentioned, I'm sure I or others will answer you.
Don't panic.
Just out of curiosity has anyone ever failed this inspection ?
If so what was the outcome ?
The other Gas Safe guy at my work had an inspection ( he’s been gas safe his full career and in his 50’s now ) don’t know what he had to do or what the outcome was because he wouldn’t tell me but my boss told me he failed it.
Hi Guys,
They are there to help not hinder. You can save up as many questions for them as they have for you. They will only ask you questions that you really will (should) know the answers to. In any event the worse that will happen is they will say we will come and see you in 3-6 months. Then you need to sharpen up a bit. The fact that your experienced and care enough to worry and come on here and pick brains says you will pass with flying colours.
Don’t be nervous, you know/can find the answer to any questions presented. Don’t guess, admit you need to look at regs/viper book to clarify, I still look frequently, you can’t be expected to learn and retain it all. I have a lot saved in iBooks - technical bullitains, unsafe situations etc so they are at my fingertips. You can be knowledgeable but not compitant, compitance comes with with time and diligence.
If it helps.... on my initial meet I was asked a lot about pipe sizing and gas pressure. He looked over my boiler which I fit and asked some basic ‘what if’ questions - all of which were easily answerable.
In my opinion they are basically checking that you are a genuine applicant and not some thicko goon, you’ve passed ACS and demonstrated competence, the rest is just fomality.
Remember he’s not there to catch you out, he ‘SHOULD’ be there to help you along the road to being independently Gas Safe and furthering your career!
Get some decent biscuits in, make him a good brew, be a nice and strike up a repor.
Job done.
Don’t be nervous, you know/can find the answer to any questions presented. Don’t guess, admit you need look at regs/viper book to clarify, I still look frequently, you can’t be expected to learn and retain it all. I have a lot saved in iBooks - technical bullitains, unsafe situations etc so they are at my fingertips. You can be knowledgeable but not compitant, compitance comes with with time and diligence.
Get some good biscuits in, be a nice genuine bloke and strike up a repor.
Job done.
I bought the company I had worked for several years. Kept the name of the company then decided to change the name. Turns out even though I was the responsible person, I didn't own the registration. I had to register a new company. Six weeks later I had my inspection. I was concerned as you seem to be. But to be honest if you keep good records and answer all the correct questions and have the correct materials if you need to check, you will be ok. If your standard is good no problems. Make sure your equipment is calibrated and upto date. Warning, do not use labels etc. It was like being back at college. Remember to tell the customer they might smell gas while your checking the meter. :).
Nothing to worry about, just be confident. Tightness test, boiler service (although not thorough, just inlet pressure, burner pressure and gas rate). A few questions about meter and flue. You will be asked a couple of questions on all the categories on your card that you’ve passed but it’s open book so if you’re not sure you can look it up. Good luck.
That’s actually reminded me of another question related to this. I’ve got an LPG crossover ticket that my old employer asked my to do yet I never did anything on site with it. So have next to no experience with it. Could I ask gas safe to disregard that as I don’t really want an inspection on LPG as I’ll be lost at sea!
I've had loads of inspections and I still worry them every time. I have no idea why I worry so much as every single time they've turned up we have a cuppa and a chat I usually get told no that changed 4 years ago so read up about that then we go off and do some work.
They want to see one of your jobs if possible if not then take them to a service or 2 if you haven't got the customers yet take them to a family member (only time they get me to do work for them is when I'm being inspected lol). They are not there to try and trick you so try and relax If your unsure of something look it up or ask.
Hi Guys,
Not sure how many of you will remember even responding to my question, but to give you an update on how it went....it hasn’t!
I’ve had two appointments scheduled with them and they be cancelled them both with a few days notice!
So can’t tell you how it went!. Is this common? I be just assumed the inspector can’t cover wveryrhing in his area efficiently and has been called elsewhere!
Reply to First Gas Safe Inspection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’m looking to retrain as a gas engineer and do a new entrants gas course. I’m a bit concerned by the ‘on-job’ work experience/shadowing, as...
Hello, I have recently had a conservatory installed, covering the full length of the kitchen. I have just failed my gas safety inspection due to...
Hi. just had my probationary inspection. Most of the inspection went ok, apart from when the inspector asked me questions about gas fires and gas...
Deleted member 120897
Hi everyone, I’m just DIYing a bathroom refurb and came across this blanked off pipe in the wall that protrudes out about 2cm. The previous owners...
Hi, need your honest views if you would be so kind. I’m 48 and work for the NHS (office based) and earn 44k a year. Ive been do fustrated and fed...
