M Mgrant Messages 910 Aug 5, 2015 #1 When using a 135 y branch is there an offset that can bring you back to square from the branch? A standard 45 degree offset isn't enough.
Best Esteemed Plumber Subscribed Messages 10,033 Aug 5, 2015 #2 It should take it back to square. Mustn't be the angle you think. Take a look at the degrees the fitting or tee say they are.
M mfgs Plumbers Arms member Plumber Gas Engineer Messages 3,468 Aug 5, 2015 #3 A 135 and a 45 will take you square, I guarantee it. Unless you have twisted either of the fittings if that makes sense?
