Discuss Wall mounted toilet problem with offset soil pipe. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi guys, I've had a search and couldn't find anything related.
Installing a wall mounted toilet, unfortunately didn't know this when I put the soil pipe in position. The supplied fitting is now approximately 130mm offset from the vertical connection. Any ideas? (amateur obviously!) Wondered if two solvent weld 90s would be tight enough? But wanted advice before I fork out £40 for the pleasure. Limited height to fit in the photographed connector that I will already need to cut down.
Many thanks,
Dave.
Can’t you get a straight one (the spigot) then a 90 on the end of that etc
You would need one from rak or similar eg geberit
Reply to Wall mounted toilet problem with offset soil pipe. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
