Discuss What kind of plastic pipe is this in the Central Heating Forum area at PlumbersForums.net
Inverness
I'm needing a type of fitting that can join copper pipe work. The plastic pipe on radiator isn't jg or hep20. Cheers
Here are the photos cheers
what do you need to change / alter?
For the basin I need too join a tee piece for a cold water supply, and the radiator is getting move,so I need to pull the piles through the floor then join a couplin to extend.
Any suggestions?
Basin your fecked on wonā€™t get a fitting in so need to open the wall up etc
As for rad you should be able to use the existing 16mm-1/2ā€ if you canā€™t you can pick them up easier enough
Have a word with bhive
And a decent set of cutters donā€™t cut all the way through spin the cutters wonā€™t deform the pipe
Reply to What kind of plastic pipe is this in the Central Heating Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
