Discuss What kind of plastic pipe is this in the Central Heating Forum area at PlumbersForums.net
Inverness
I'm needing a type of fitting that can join copper pipe work. The plastic pipe on radiator isn't jg or hep20. Cheers
Here are the photos cheers
what do you need to change / alter?
For the basin I need too join a tee piece for a cold water supply, and the radiator is getting move,so I need to pull the piles through the floor then join a couplin to extend.
Any suggestions?
Reply to What kind of plastic pipe is this in the Central Heating Forum area at PlumbersForums.net
I am told I need to replace my boiler. I am considering a system boiler so I can lose the tank in the loft and feed it direct from the mains...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
L
Hello Please could I have some advice. I recently had an new air source pump and hot water tank system installed. The pipes to the radiators...
