Discuss Water level in toilet pan drops in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
clivediyer
Hi Guys,
We live in a 4year old, 3 floor town house with a toilet on each floor (very useful when you reach a certain age!). Recently I have noticed that the water level in the toilet pan drops by 50-75mm soon after flushing. The flush works well with no rise of level in the pan which might indicate a blockage.
Has anybody any ideas:confused:
Are they all linked to the same soil stack? How about the other traps on the sink, basin, bath etc? Also, is it a standard pan or a syphonic? And does there seem any problem in flushing the waste away (i.e. fills particularly high before disapearing)?
Hi Resolute
The top and middle floors are linked to the same stack. The other traps seem to be OK (no smells). It is a close coupled pan. I had thought perhaps agood plunging would help?
Thanks for your interest
Clivediyer
does it happen when you flush the middle one? or does the middle one level drop only when you flush the top floor one.
sounds like the water from the upper floor bog is syphoning the trap from the middle bog as it runs full bore in the pipe past the middle floor branch.
has this problem always existed or just started??? check operation of aav if there is one. or fit a branch ventilation system to break the vacuum
KJ
Sounds like self siphonage, suggest installing an AAV on branch line by W/C, could be on the basin run if it connects to 110mm before main stack.
Reply to Water level in toilet pan drops in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey Guys I’ve noticed this weekend that my en-suite toilet pan water level is seeming to regress after an hour. Toilet flushes as normal and...
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming...
