Discuss Waste adapter advice needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all new to forum and to plumbing, can I have some advise on what fitting to use to go from one inch copper waste to 32mm plastic and the best place to get one from. Thanks in advance Nik the gas man(never make a plumber)
compression waste fitting, any plumbing merchant, some people call them "macalpine socket" as thats the well known brand
Must be inch and half ? Ideally cut some of the pipe off and take it with you
Reply to Waste adapter advice needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
