Discuss want to fit tmv2 but supples to basin taps not balanced pressures in the Australia area at PlumbersForums.net
have gravity hot, mains cold to basin taps,require to fit a tmv2
anything i can fit to avoid trying to get gravity cold to taps to balance
Simong said it all mate ,
Make sure you get one that can adjust down to a low pressure,
Youll find they have different min and max pressure adjustment
[automerge]1572538160[/automerge]
Also you know you can adjust the head on the tmv to open close the hot.
Reply to want to fit tmv2 but supples to basin taps not balanced pressures in the Australia area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
PSxxxxxx
