Discuss want to fit tmv2 but supples to basin taps not balanced pressures in the Australia area at PlumbersForums.net
have gravity hot, mains cold to basin taps,require to fit a tmv2
anything i can fit to avoid trying to get gravity cold to taps to balance
Simong said it all mate ,
Make sure you get one that can adjust down to a low pressure,
Youll find they have different min and max pressure adjustment
[automerge]1572538160[/automerge]
Also you know you can adjust the head on the tmv to open close the hot.
Reply to want to fit tmv2 but supples to basin taps not balanced pressures in the Australia area at PlumbersForums.net
