Discuss Ultimate Tile Drilling Box Set diamond drilling cores for professional installers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
365drills
[video=youtube_share;yrfDZk6hFeI]http://youtu.be/yrfDZk6hFeI[/video]
Ever wanted to own a complete drilling solution for installing hard porcelain tiles but were put off by the high initial outlay? Well at ********* we solved the cost problem as well as the drilling problem. This hamper of goodies has been carefully put together for the full time porcelain tile installer. Its not for hobby or DIY. For years you have been asking us why we didn't develop a solution to cover every event. Well we listened and here it is. Each piece has been carefully selected to make sure it earns its keep. Our best selling solution (The bathroom fitters kit) at £49.99 still represents excellent value for money but with this solution you get your hands on even more useful equipment.
http://*********.com/boxset/porsadrillmax6002.jpg
LIMITED EDITION: This is the ultimate set put together for tilers, installers and plumbers.
Whats included ?
What is it ?What is it used for ?
2 x 6mm For Red Rawl plugs and small fixings
2 x 8mmFor Brown Rawl plugs for heavy duty fixings
1 x 16mm15mm pipework, copper, plastic, water feeds, fisher fitting kits, rad pipes
1 x 30mm22mm pipework, 28mm gas, Shower rose, Body Jets.
1 x 40mm32mm waste pipe for a sink.
1 x 45mm40mm (ID) waste pipe for a bath or shower - Push Button flush
1 x 60mmShower valves, Push button flush (large) Waste trap for showers
1 x 115mmExtract fans and soil stacks.
1 x Water SpongeTo cool the diamond cores consistently and collect dust
1 x J-HookTo remove (eject) the tile from inside the cores perfect on small sizes
1 x Main Guide PlateAnti slip guide for sizes 6 8 16 30 and 40mm
1 x Back up plateAs above but you also get a spare plate included
1 x 45mm Guide PlateAnti slip guide for the 45mm. Also has other sizes on the plate.
1 x 60mm Guide PlateAnti slip guide for the 60mm. Also has other sizes on the plate.
1 x heavy duty caseKeep all your diamond cores together. Easy to spot colour.
Wow !
The most comprehensive set we have ever sold !
http://*********.com/boxset/porsadrillmax6003.jpg
The main tray contains a 115mm a 60mm and a 40mm
http://*********.com/boxset/porsadrillmax6004.jpg
The top part contains a 45mm and a 30mm plus a J Hook
http://*********.com/boxset/porsadrillmax6001.jpg​
What is the item / size?What is the price if bought outside of the kit
2 x 6mm £15
2 x 8mm£15
1 x 16mm£15
1 x 30mm£18
1 x 40mm£30
1 x 45mm£35
1 x 60mm£40
1 x 115mm£60
1 x Water Sponge£2
1 x J-Hook£5
£235 if bought separate
The Cost of the separate items would come to £235
Purchased separately from our main site the diamond cores would cost you £235.
LIMITED EDITION PRICE:
[SIZE=+2]£235 ? £199 ? £150 ? £135 ? £125 ? £115 ? [/SIZE]
[SIZE=+4]£99 !! [SIZE=+3]including VAT[/SIZE][/SIZE]
Order Here
[SIZE=+2]THAT WORKS OUR AT A MIND BLOWING £9.90 PER DRILL BIT[/SIZE]
You could not BUY a diamond drill in a shop for £9.90. This is insane value for money.
We only have 50 of these in stock and once its gone... ITS GONE.
YOU SAVE: £136..... (£235 - £99 = £136 !)
That's only £82.50 if you are VAT registered... So your cost is £8.25 per drill bit,
http://*********.com/jpgs/guideplate.jpg
Order Here
Cheers Croppie yes it is and we wanted to make people aware that this set is ONLY available direct from the factory. You will never be able to buy it from the shops at that price because the distributors would add about 40% and the retailer about 40% giving a true retail price of about £199 to £249 for the kit.
looks good will be good to keep in the van for these tiling jobs
Picture of the boxset part of the bundle closed.
Reply to Ultimate Tile Drilling Box Set diamond drilling cores for professional installers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Brand new for April 2016. Launch of boxsets for drilling holes into very hard porcelain tiles. Two sets have been revamped. The third is...
365drills
  • Locked
Here they are! Totally refreshed for this year. We have given a makeover to all of the BOXSET range. All options are now presented in smart...
2K
365drills
  • Locked
We WERE out of stock but great news as of Feb 2015 we have made a new batch of these. BACK IN STOCK Back in stock as of March 2015...
365drills
  • Locked
E. K. Wilson of London is a prefered stockist of PORSADRILL diamond core tile drills. If you need ********* core drills in...
365drills
  • Locked
A positive early response to the "Installer Magazine" splash on PORSADRILL. Tile Drilling Specialists 365-Drills have modified their publicity to...
2K
365drills
