Discuss Ufh in timber ground floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
I'm building a single story rear extension and would like to use UFH
It's going to be a timber joist for with 22mm chipboard flooring running from a combination boiler
What is the most effective way of installing the UFH?
1) spreader plates.
2) celotex between joist with a biscuit mix
3 or something else?
Thanks Russ
Infil with insulation then cut your chip board to infill between the joists so your not raising your height then over lay ufh system
Find it’s the best of both worlds
Reply to Ufh in timber ground floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
