Discuss TRV Identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sam Wardill
Does anyone recognise the make (& ideally also model) of this TRV?
I'm trying to fit a controller to it. It doesn't work with the Pegler Terrier i-temp i30 Programmable Thermostatic Radiator Valve
Reply to TRV Identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive. I am looking for an adapter that will be able...
Hi, I need some advice. I am trying to replace the manual radiator valves on a towelrail with a TRV: I ordered a Myson 2TRV15SN, and the tail seems to be identical with the current setup, however I am not sure who to attach the copper pipe at the bottom. This doesn't seem like a standard...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am wondering if it's worth turning on the optimum start and stop features? There is also something called TPI (chronoproportional control) but I'm not sure how...
