Discuss Toilet Damping Grease in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I am looking to obtain some toilet damping grease for slow close toilet lid. The grease is of extremely thick sticky consistency and translucent. I have found a source in China, Keermo KM-508 but would like to source something similar in UK. Does anyone know of any grease suitable for this job as the ones I have found so far are useless.
I used to use a very thick grease years ago for a non plumbing use called Rocol Kilopoise.
Unfortunately no longer available, probably due to one of the ingredients being banned.
There's an alternative but it's very expensive, PG44a £35 plus vat for 50gram
Have you tried Vaseline, that's quite thick.
Thanks for your suggestion regarding PG44A. Further investigation led me to Tribosyn PG44A. The company selling it states "Tribosyn PG44A is a match/equivalent to the Nye Lubricants PG-44A grease – same formulation and performance but a lower price, so we are recommending customers switch to Tribosyn PG44A."
At £19.50+VAT for a 30g jar its worth a try.
Vaseline just isn't thick or tacky enough
I have the same problem with an ideal standard toilet seat where the damping on one side has almost failed completely
I am planning to try some high temperature axle grease I have in stock - has anyone tried this before?
Reply to Toilet Damping Grease in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
Hello everyone Moved into a 5 year old ‘new build’ property recently and the toilet was leaking from where the tank meets the bowl. Nothing...
Hi everyone, I moved into a new build three bedroom, two bathroom bungalow about 2.5 years ago. Ever since we moved in there has been an issue...
6K
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Hello, Recently I received an unusually large water bill which led me to the discovery of leaking flush valves. I have two toilets and it turned...
