Discuss Thermostatic Valve Head in the USA area at PlumbersForums.net
Following on from my previous I have now received my Bulldog Thermostatic Valve Head as pictured below and removed the previous ring however I am finding it hard to find the position for it to slot into place and turn the ring to fix into place - any advice for a extreme novice like me?
Should just fit you might need to line it up with the internal hex eg turn it a bit left or right till it seats
Yes best to open it all the way eg highest setting
I’ve managed to get it back on now Shaun! I’d like to know if I removed the valve originally and it was set on 3 for example when I have placed the new head on set to 5 will my max only go to the temperature 3 in theory if that’s what it was when removed or does it reset when dialled back to 0?
No the head controls the temp so new one will not need resetting
Reply to Thermostatic Valve Head in the USA area at PlumbersForums.net
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
V
Hi All, Hope all are doing great. I have replaced two separate tap of my bathtub by mixer tap with thermostat. Previous with two separate tabs...
Deleted member 120897
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
