Discuss Supply Run and Connect Gas Hob - Windsor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Colour Republic
Hello guys,
Been a long time but thought I’d try looking on another of Dan's forums for a Gas safe engineer.
We are doing a job in Windsor way out of our normal area and need a gas safe engineer to run a supply of approx 6-7m from the nearest and only appliance, the boiler (which is currently supplied in 22mm) to a new 6 ring hob.
Supply may need to be run on the exterior of the property. There is an easily accessible crawl space under the property but may not be well ventilated enough to allow the pipes to be run under. Either way it's a nice straight forward job with easy access, I know you hear that all the time!! But it really is!! Only spanner in the works is if for some reason you think it needs a new supply from the meter in 28 to service boiler and hob. (Current run from meter to boiler in 22mm is approx 6-7 meters)
We are more than happy to run the pipe work ourselves and wait for final connections from yourself. Whichever way you want to work really. Depends on your work load.
Job would need to be done within the next 2 weeks which is when we leave site.
Anyway if anybody in the Windsor/Slough/Maidenhead area is interested give me a quick PM and I’ll give you a call. Or if one of the mods knows of a trusted plumber in the area give me a quick nudge too.
Cheers all
Rob @ Colour Republic
thank you for posting this. if anyone is interested can they contact the op directly thank you.
Reply to Supply Run and Connect Gas Hob - Windsor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Im fitting a kitchen in my own house . When removing the gas oven on a bayonet fitting and turned the gas hob off and removed a four burner gas hob. Ive noticed that the oven supply 15mm and the hob supply is 15mm but once the cupboard is out i can see the hob supply is 10mm in the wall. Which...
Hi, I’m changing my kitchen and swapping from a gas hob to an electric induction hob. Rest assured, I have no intention of doing any work at all on the gas supply, I just have a question. Assuming we might want to go back to gas at some point in the future, it may be worth leaving an easy...
Our House is now fully Heat Pumped, insulated and we have had the Gas Meter Removed. We have a 1950s foldaway Cannon Gas Grill which is on the wall above the AEG Induction hob with 1 Gas burner. It worked very well on Natural gas. We have had the local gas co. install an LPG supply using...
Hi all, Does anyone have any feedback as to which is best. Running the pipe from the outdoor gas meter to a new boiler on an outside wall or run the pipe under the floor (suspended timber) which is our existing setup and the new boiler is being sited in same location as old. I ask just in...
Hi All, I need your advise as I'm really concerned here. I only just had regular boiler replaced with combi (Vaillant ecoFIT Pure 25kw). I had few surveys done and everyone stated the gas supply pipe from the meter to the boiler must be changed from current 15mm to 22mm. The plumber I used said...
2K
