Discuss Suggest gas combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Red Drawf covers situations like this.
Smeeeeeeeeeeeggggggggg Heeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaaad.
On a serious note.
If you go down the unvented route.
1. Check static pressure.
2. Check dynamic pressure.
3. Check flow rate.
4. Make sure the installer is g3 certified.
5. Make sure the installer doesnt make numbered lists. Really irratates the life out of me.
My opinion is you are worrying too much about the small things.
You are looking at figures why not speak to family and friends and see what boilers they have go and stand next to them and you will see that you will not hear them unless you are listening out for them.
On an 28kw combi there is a maximum flow rate that all manufacturers can get out using 28kw worth of gas and most manufacturers have got the most they can get on hot water rates this will still not be enough to run 2 taps at the se time without a temperature change.
You are on about the power consumption whilst idle and whilst running, instead of looking at things like that look at the cost of parts and the time it takes to change the parts, if 1 boiler saves you £100 in electric over 10 years but the parts are more expensive or harder to fit then it will lose you the money that you have saved.
To me the what anybody should be looking at is reliability, manufacturers aftercare and warranty. As you could find the perfect boiler that meets all your specifications and with a long warranty but if it goes wrong you could be without a boiler for a week instead of a day etc.
It does seem that you are being penny sensible but pound stupid.
didnt the OP say it needs to fit into a kitchen cupboard? this will limit many boiler choices and the option of recovery unit.
the baxi plat is a very loud boiler, the WB CDI classic is really quite imo. I guess it depends on the environment its tested in, most washing machines will be louder unless you get one of these
as your having a shower when the boilers making a loud noise and it will be on low for the UFH noise should not be a great concern
It doesnt have to fit in cupboard, but ideally would like to. Purely for visual view +cupboard will reduce some noise.
New posts
Reply to Suggest gas combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and...
Hi all. I recently upgraded our CH system, but rather than the expected drop in gas consumption, Octopus is saying we're using roughly 30% more...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
