Discuss Sparky Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Steve @ TheHeatingHub
Ok so firstly I am not a big fan of electics but would like to get some info in regards to the following project.
I have a new house (2009) so the main board has rcd protection and the wiring would conform to the regs in that year I am not certain about the month though.
I need to get power to the garage outside (5-15meters away depending where I put the power socket in the garage) but am unsure of the best/legal way to do so.
My first thought was to add a rcd spur to the downstairs socket ring main and run 2.5 armoured cable underground(is there a specific depth?) into the garage and stick a double socket(used for lights and a fridge) which I thought would be fine. However I would like to turn the garage into a pub and do not think that 1 double socket will be enough and I do not want to have some shock horror multiple 4 plug extension lead scenario :)
I have now thought that it would be better to extend the ring main (not sure of the best way of doing this, just remove a socket and use a junction box?) that does not sound like a great idea but does it meet regs ? I have even thought about putting in an additional fuse box into the garage for better protection but I cannot get a cable back to the consumer board in the house. I would have preferred to do it this way.
I know guys at work with part P but know feck all about electrics so was hoping onw of you guys could help me out :)
thanks in advance
Try popping over to the electricians forum
aye have just registered just noticed the tab at the top hehe :)
Best advice I can give is buy yourself a treble skinned tin helmet before you go in there asking questions.
Nah!, they are pussycats since the Plumbers Forum showed them the error of their ways.
thanks in advance
I know I'm going to get flack for this. But shouldn't you get a sparky, and take our own advise about using professionals.
It's a notifiable job so will need signing off just like a boiler. You could take a spur off the ring into a glanced junction box then steel wire armoured cable into garage. From here you could go into a garage unit protected by a 13A MCB and a radial circuit for sockets as long as you like with as many sockets as you like. The best solution would be to tael a new circuit off the consumer unit but if this is no way possible you've not got many other options.
No edit button glanced should read glanded and tael should read take !
so could I spur of a ring main and put in an additional consumer board and wire up plugs and lights off of that ? Small load of couse
You can spur off the ring main via a 13amp double pole fused spur then run into the garage.
What you do afterwards regarding a consumer unit, radials etc is up to you.
Just remember that your main circuit on the house emust be protected by a 30ma RCD and your garage supply will be limited to 13amps.
thanks for all your help:) I'm currently digging up the garden for the duct and amoured to go down, this is worse than working in lofts :/
Just thinking about this, there is no reason why you couldn't spur off in 6mm and have 32A out into the garage as far as i'm aware.
Sorry, A spur off of a ring feeding radials needs to be as I described earlier IMO.
OCPD is 32A, cable is capable of this easily (could use 4 mm but was taking into account de rating factors of buried SWA cable) can't see a problem myself. The 13A is only there to protect the cable, which we would assume to be 2.5mm due to terminal size issues.
If your taking it into a garage board the radials can be protected accordingly at the board.
I'll pop the question onto the electricians forum and double check as I may not be aware of a specific regulation preventing this.
Reply to Sparky Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi can anybody help me with a problem I am having. following a power cut the heating and hot water failed. The boiler would light but it would go...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Full disclosure, I am an Electrician. One of my older clients has just had her fire capped off because it doesn't comply with today's regs and...
I would like to add an additional radiator to our central heating system. We have an attached double garage converted to a man-cave and workshop...
