Discuss Shower Trouble (this should be easy to answer!) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
c00kyb0y
Hi board,
I'm currently using an electric shower - but the flow is useless.
So I've noticed that our bath taps has an outlet/adapter to screw a shower hose onto (we've only just moved in, last owner must have got rid of the hose). Anyway, it's about 26mm dia, and the shower hose we are using has standard ends on (about 1/2")... can anybody direct me in the way of a good website or anywhere that sells these ? I've had a little look but to no avail.
Thanks in advance.
Chris
any plumbers merchant should have a hose, even B&Q. Could you not use your hore from your electric shower?
Also. replacing the hose and head on the old shower might work
The hose I have has 1/2" connectors at each end, I need a hose which will connect to the adapter/outlet on my taps which is about 26mm DIA.
yeah plumbers merchant should sort you out.
how is the pressure at your bath? i would never recommend having a shower coming from bath taps due to pressures being different between hot and cold systems. i sometimes find that in electrics showers have poor flow due to the hose or the head being blocked. try taking off the head and turning it on and see if the pressure gets any better.
Just tried the electric shower without the shower head, the hose is brand new so I know thats ok, the water was fine cold - soon as I turned the heat switch round to warmer water the pressure just dropped to a very poor flow.
that means the shower is finished. get a new one, or if you want to get one for the taps plumbers merchants and possibly even B&Q will have a slightly larger hose or even an adaptor/reducer fitting so you can use the hose. good luck
Hi board,
Thanks in advance.
Chris
you will not find a hose to fit this, part of the tap is missing there should be a cradle on top to hold the shower which has the 1/2 inch connector on it for the hose
you should maintain it everyday.If you would not like,change one,buy a new [DLMURL="http://www.showerroom-bathroom.com/shower-room-c1.html"]shower room[/DLMURL]
Reply to Shower Trouble (this should be easy to answer!) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
