Discuss Shower leak, wet patch getting larger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Omeo
Hi
I had a wet patch that appeared on my dining room wall close to the ceiling so I assumed it was coming from the bathroom directly above. I have recently moved in after decorating and used the sink and toilet before and the bath but never the shower.
A plumber I know came and took the bath panels off, filled the bath with water and released to see if any leak could be coming from the bath, no issues. So we sprayed water from the shower on the sides of the bath where the tiles and bath meet and noticed straight away water was leaking down the side on to the wooden floor board. We noticed that the silicone sealant was not done correctly as there were gaps so we removed the silicone and re-siliconed. Also did this while the bath was weighted down.
However the wet patch is slowly increasing in size but no water is leaking through. I was advised that as I had two long showers a lot of water would have seeped through and the moisture is drawing the water through the wall which will eventually begin to dry out.
Does this sound right?
started using the shower on Saturday and Sunday. Noticed the leak Monday night. repaired the silicone on Tuesday but have not used the shower since Sunday except for the leak test.
Give it a good blast and see what happens. I would have expected to see it start to disappear by now.
Yeah, could take a week but you should see it disappearing gradually
How is the tile grout? Any hairline cracks? Look carefully as water will find the gap!
Reply to Shower leak, wet patch getting larger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and...
Hey guys I know this ain't plumbing. But some of you may know. I have a small bathroom but water seems to leak to the kitchen. I realised under...
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
