Discuss screeching in pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
brip
Hi all, I have a customer with a Stelflow unvented cylinder installed approx 18 months ago. All taps, showers, toilets are new and for use with a high pressure system. When a hot or cold tap is opened (90% of the time) there is a screeching noise in the pipework, it doesn't disappear by opening more than one outlet. I'm assuming the pressure is too high, but havent taken any readings yet.
The uv cylinder is in the garage and the cold water to the house is not taken from the tapping for balanced cold water (this has been used to feed the top up for the sealed boiler!)
Any suggestions graatefully received
If I remember correctly there was some issue with the expansion vessels on these, there was a thread on it some time ago.
check pressures on incoming, if the cold feed isnt taken off the balanced outlet then it could be v high plus any mixer taps and mixer showers will find it hard to work correctly.
Thanks Roger, had a look at the threads and will be checking the pressure etc tomorrow, very helpful cheers
Hi, thanks cheecking pressures was my next option, but having read the threads on these expansion vessels I'll look at that first
Reply to screeching in pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which I and other residents in the building share as we have shared supply to bathrooms and kitchens) Under kitchen sink stop valve turns off cold water in...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi I've got water hammer issues with my cold feed and some with the hot feed. When the cold sink tap, cold bath tap and thermostatic shower in the main bathroom is opened and closed there are hammering sounds from the living room ceiling. It sounds like knocking. There's no hammering whilst...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume...
