- Messages
- 998
Hey guys hows it going? need a bit of help did not want to post in the public oil forum & its not a gas boiler so here I am.
Greenstar Worcester heat-slave 18/25 oil
Went to Look at a leaky boiler today - No prob's, leaking flow switch remade joins shes okay no leaks.
Go to recommission the boiler, turned her on set both the boiler stats HW & CH to about 3.
Waited for about half hour, fecking thing is still running, another 15 mins.... still running(the boiler was warm when I arrived) Room Stat is not calling, Hot tap not running. Heat bank in boiler getting a little bit too hot for my liking.
So I turn Both the boiler HW & CH stats to their lowest setting & made sure the room stat was not calling, Shes still running.
The rads are getting bouncing even though no stats are calling. The hot water comes hot for about 30 seconds the goes luke warm.
What do you guys think? I'am thinking that the CH micro switch on the diverted may be stuck on.
Anyone come across a fault like this before, its not often I come across a boiler that wont stop running.
cheers
cheers
