Discuss Rotate branch on soil stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
honeymonster
Hi there,
I have a pvc soil stack which unfortunately runs inside my house in a cavity wall. Currently the branch for the toilet waste comes out 90 degrees to the wall, under the floorboards and through a hole in the floor for an old style vertical waste toilet.
I need to rotate the toilet part on the stack 90 degrees so that it runs parallel to the wall (so i can feed it along the inside of the cavity wall and then run it horizontally through a hole in the wall) allowing me to fit a new toilet close to the wall.
I hope I've explained this well enough. What I need to know is, can I just rotate this part of the stack? Or am I going to need to buy a new part/reseal it etc etc?
thanks in advance
Maybe you can , maybe you can't, it all depends on hoe the stack was put together.
If the fittings are solvent cemented then its solid and you cant move it, you would need to cut a section out and replace as necessary. If on the other hand its pushfit then you "may" be able to move it , it depends on whether the plumber used proper silicon grease on the fittings or some other lube like soap or fairy liquid. The silicon stays put and you can generally move the fittings years after, unfortunately soap/fairy will dry out and the fittings will be very difficult to move.
You will have to check the stack and if its pushfit then give it a tug and see what happens.
A word of warning though, if the fitting will turn it often turns the whole stack which can be a problem if you have other waste pipes connected into it as well.
Cheers Nick, I'll give it a wiggle and see what happens. Will keep my plumber on speeddial incase it all goes wrong!
Tom
yeah be careful u could have waste water leaking - push fit is easier in a way - bear in mind u dont too much of along run from the bog to stack and needs to be slopin aswell -
there are water regs that may need to be applied here too
Nicks advice is good sound advice.
You can also get silicon spray to try on the push fit joints if you can see them that is. If you can't get silicon spray, try some spray furniture polish if its the sort with silicon in, some pvc window installers say to use that on their door locks.
Its avoiding using anything with hydro carbons in it on pvc. Because plastic stuff is made from hydro carbons it melts it down if you use the likes of ordinary engine oil as a lubricant.
Washing up liquid has a degreasing agent in it and so it effects the rubber rings not the pvc if I remember right. Could be wrong though it maybe the other way around, but which ever it is, the joints go solid if its used as a lubricant.
Reply to Rotate branch on soil stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
