Discuss room stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
brian_the_gas
Hi, please can someone answer this question!I have a worcester 26cd1 xtra combi and want to fit a room stat, the installation manual gives instructions for a wireless stat but as these are quite expensive, can I install a conventional stat ( hard wired ).
Thanks in advance
Brian.:confused:
there is normally a link somewhere in the intenal wiring, you simply fit a two wire stat, i would always go for a programmable rs
Thank's for the advice, but when you say programmable,do you mean the wireless ?
Reply to room stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
