Discuss room stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
brian_the_gas
Hi, please can someone answer this question!I have a worcester 26cd1 xtra combi and want to fit a room stat, the installation manual gives instructions for a wireless stat but as these are quite expensive, can I install a conventional stat ( hard wired ).
Thanks in advance
Brian.:confused:
there is normally a link somewhere in the intenal wiring, you simply fit a two wire stat, i would always go for a programmable rs
Thank's for the advice, but when you say programmable,do you mean the wireless ?
Reply to room stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
