Discuss Plug and play Bidet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rpm
Subscribed
Came across this the other day thought I`d share.
dont lean on the seat sensor and go whats that button do like I did the first time I came across one, not nice, but water was warm :)
what you think rpm?
I steered a wide bearth of the thing mate, was tempted to press a button but knowing my luck ....
you want to see the complete version which isnt an afterthought conversion, lovely bit of kit, warm water, warm air blow, music and loads of other completely useless tricks only cost ÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁ
will post a pic in about a week and 3.5k
That poor toilet pan with all that rubbish bolted to it, a sanilfo and now this..
That pathetic warm jet wont help my bottom on a sunday morning, I need to be bent over in a carpark and hot washed with one of these...
We fitted one of these the other year when we fitted a new bathroom for an old couple.
Me, being the young one, had to sit on it to check it all worked
Me, being the young one, had to sit on it to check it all worked ����
Reply to Plug and play Bidet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A simple procedure has turned difficult. I am trying to disconnect a floor-mounted bidet so I can change the click clack waste. All is...
Hi.. I am after advice on installing a bidet in a toilet with the water valve hidden inside the cistern. I am renting. Is there anyone with a...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
Hi, I note that the Grundfos Alpha 2 requires a special plug to connect the electric wiring. Are those plugs reusable if rewiring is needed...
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
