Discuss Plinth heater quandary in the Plumbing Jobs | The Job-board area at PlumbersForums.net
123Pipes
Hi all, I am looking to put a plinth heater under the kitchen units, but the only pipe work that is available are the main boiler pipes. The pump is in a cupboard upstairs, after my proposed connection point Can I use these. And will it work if I just wire it from the time clock , and controlled by a room thermostat in the same room?
If your system is open vented, it won't work! ( wrong side of the pump)
Sorry for not mentioning , it is a sealed system. The boiler flow & return pipes are 28mm.
Because of the position of the pump, am I likely to feed the heater with cooler return water. Would swept tees help to get the flow into the heater better if the were in the right orientation.
You can't connect between the boiler and pump. It's on the section side of the pump.
if its a sealed system the heater will act as a bypass it will probably work but would be uncontrolled
Reply to Plinth heater quandary in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've recently replaced an immersion heater for a direct cylinder, for 2.75-3kW. The new one seemed to be working a week before I got a callback. I...
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my...
eco-heating options
E
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
I would like to add an additional radiator to our central heating system. We have an attached double garage converted to a man-cave and workshop...
