Discuss Pegler xpress fittings-job lot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Job lot of pegler xpress fittings
10 x 15mm straight couplers
21 x 15mm elbows
14 x 15mm 135 bends
14 x 15mm street elbows
20 x 15mm equal Tee
1 x 22mm straight coupler
2 x 35mm straight coupler
7 x 35mm 135 bends
5 x 35mm 135 street bends
Almost £300 worth I reckon
Selling as a job lot
Collection from Aldershot preferred, But I can post if necessary
£200
Reply to Pegler xpress fittings-job lot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Have a little job under kitchen sink and need to know how to identify fittings (valve, tee, coupler) suitable for drinking water. Should I be looking for only EN-1254-1 or EN 1254-2 or something else? For example, is this one good for drinking water...
1K
Deleted member 120897
Hello guys, first post here. While I prefer copper-and-solder, I've used compression fittings successfully in the past, and I opted for compression throughout the present job because I'm tight for space. I got most of the fittings from the local Toolstation. They're standard 15mm equal tees...
The rusty bit with a hole at the top looks quite old, feels flimsy, and is a single skin 100mm x 400mm. The boiler has a 600mm new pipe rising vertically, then a new 135 degree bend (although the paint has come off as you can see), then the rusty pipe, another 135 degree bend which looks very...
  • Locked
Please Read Full Description/ I Am Manchester Based Plumbing And Heating Fittings/Materials/Consumables 1000's £££££££ Various Items(See List Below) Sold As Job Lot Items That Are Included Are :- 200 x 90° Elbow Bag of 25 25 x 22mm Solder Ring 90° Elbow 100 x 15mm Solder Ring 90º Elbow 50...
2K
  • Locked
ALL FOR SALE 33 x 1.4401/316 - ø28/ø15 10 x 1.4401/316 - ø22/ø15 19 x t connet ø15/ø15/ø15 26 x 90 degree ø15 17 x ø15/R 0.5" 02 x ø15 45 degree 06 x ø15/Rp.5" 11 x ø22/ø15/ø22 06 x 22/22/22 02 x 22/22/Rp.5 09 x 22mm chrome elbow 09 x 22mm chrome straight 05 x 15mm chrome elbow 03 x ø22/R.5"...
2K
