Discuss Job lot Plumbing & Heating fittings/consumables in the For Sale & Wanted area at PlumbersForums.net
Please Read Full Description/ I Am Manchester Based
Plumbing And Heating Fittings/Materials/Consumables 1000's £££££££
Various Items(See List Below)
Sold As Job Lot
Items That Are Included Are :-
200 x 90° Elbow Bag of 25
25 x 22mm Solder Ring 90° Elbow
100 x 15mm Solder Ring 90º Elbow
50 x 15mm solder Ring Tee
25 x 22mm Solder Ring Tee
25 x 22mm Street Elbow
25 x 22mm x 22mm x 15mm Tee
75 x 15mm-10mm Compression Reducing Set
25 x 22mm End Feed Coupling
65 x 8mm End Feed Coupling
75 x 10mm End Feed Elbow
25 x 10mm Straight Coupling
50 x 15mm Coupling
18 x Lead Free Solder
3 x Rocol Gas Seal Paste
12 x Rocol Gas Leak Detector Spray
3 x Altech Air Duster
3 x Red Regin Smoke Pellets
5 x Aluminium Foil Tape
2 x Advance AT293 Closure Plate Tape 10m
1 x Fry Powerflow Flux
13 x Inhibitor
1 x F3 Cleaner
3 X Cura Cleaner
5 x Solvent cement glue
50 x 15mm x 1 1/2" Flexible Tap Connectors 10 pack
4 x M10 x 15mm Flexible Monoblloc Tap Connectors
5 x M12 x 15mm Flexible Monobloc Tap Connectors
1 x M10 x 15mm Pushfit Flexible Monobloc Tap Connectors
10 x 3/4 x 22mm Metric to Imperial Coupling
6 x 1 1/4 Swivel 'P' Trap
3 x Fluidmaster Telescopic Anti Vac Bottle Trap
7 x Opella Adjustable Arm Bottom Entry Fill Valve
2 x Bath Trap
2 x Wirquin Macdee Syphon
Also I Have (see pictures)
6 x TM6192 Ravenheat Replacement Programmer
9 x Ravenheat 0008VAL01018/1 Pressure Relief Valve
5 x Ravenheat 5012051 Diaphragm
2 x Ravenheat 0005PRE03010/0 Low Water Cut Off Switch
The Box In The Last Picture( Posted 2 Photos So You Can Try To Gauge The Amount Of Fittings Has Various Items.
Including :-
1 x Honyewell Two Port Valve (It is New Just Not In Box)
35 x 15mm end feed elbows
2 x compression pump connectors
5 x 22-15mm Compression Reducing Set
100's Various Fittings
There Must Be a Good Few Hundred Quid there alone
Sentinal Eliminator
Testo 327-1 Flue Gas Analyzer (Think It May Need New Cells) But In Good Condition
1200 x 600 Single Panel Radiator
Ravenheat CS80 Boiler (Heat Exchanger Remove,But Other Parts Still On It, Could Be Used For Spares)
Hot Water Shower Pump (Used)
Advertised Elsewhere
I Have Some More Tubs Of Fittings Etc (Too Much To List), More Parts. Willing To Add Them Aswell. But The Ad Is a Ruff Idea Of Just How Much Stuff I Have And What It Is Worth
PRICE £1250
Pm op if your interested if you not don’t post
Reply to Job lot Plumbing & Heating fittings/consumables in the For Sale & Wanted area at PlumbersForums.net
