A
Aldred1990
hi guys what size drill bit would you recommend for drilling the hole for 15mm copper pipe. thanks
Discuss outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
110 mm core bit
18mm hole with the grey tape to protect copper...
Queue the onslaught...
Keep it tight and use this, for best job ever.
DCV fitted inside ?
I use a 16mm bit first followed by a 20mm bit and insert 20mm electrical conduit which the 15mm copper glides through:
View attachment 13986 View attachment 13985
my only issue is that you cant drain the water out over the winter if you pipe it upto the tap
Which is why I fit a drain cock too.my only issue is that you cant drain the water out over the winter if you pipe it upto the tap
cheaper to pipe downwards and open the tap to drain it
neat keefy, why sleeve it alot folk do and dont some time i do some i dont,
I have always sleeved as best practice, particularly down to the corrosive effects of the brick mortar in copper piping.
I used to use a piece of 22mm copper as a sleeve but decided that if the cement/mortar is particularly corrosive then all you're doing by using a copper sleeve is postponing the innevitable leak that could arise. Plus electrical conduit is dirt cheap and looks neater.
Reply to outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
