Discuss newly replaced rads are cold? :S in the Plumbing Jobs | The Job-board area at PlumbersForums.net
obseen16
hi all. i just replaced 3 rads in my folks home. the system is a 1 pipe system (never seen a 1 pipe system before) trouble is i removed 3 old rads 35yrs old if not older. anyway after replacing them one gets hot but the other 2 are barely luke warm. one pipe is hot but the other is cold and the rads aint getting hotter. could this just be a balancing problem? the old ones worked fine.
got me puzzled a bit.
all the pipework has remained the same no alterations just new rads and valves.
hope someone can help
cheers
J
all valves on?
the rads that are warm turn off one side then go check the cold ones, bleed pump bleed rads
could be a right game getting it going but best way to do it
its a one pipe system, poss air lock or sludge.
turn the pump up to full speed.
Sometimes when you drain old systems the pumps never seem the same or pack up completely , might be worth having a close look at the pump.:)
shut off lockshield on the hot rad and the lockshield on any other hot radiator ( i assume there are more than 3 rads in the house). When the new rads get warm, bleed em and then introduce other rads gradually.
I would say it is defo a balancing problem. Water will always take the easy route,
thanks guys. great advice,
i thought it might be more likely to be a balancing problem so after writing the first post i did go and shut off the other valves in the house. thanks for the advice it was really helpful and nice to know i was on the right tracks lol.
many thanks (once again)
James. ;)
Don't forget one pipe systems benefit from 'full bore' rad valves.
Reply to newly replaced rads are cold? :S in the Plumbing Jobs | The Job-board area at PlumbersForums.net
