Discuss Newbie toliet fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DogsDinner
I had bought a 'back to the wall' toilet, I feel quite confident, apart from the waste, I think I will need a flexi pipe? the soil pipe I am connecting comes up through the floor and measures 5" diameter. What is the product I need?
Thanks!
Is the existing soil pipe plastic or cast?,if cast ,is it a collar that is 5'' ?,picture maybe good
It's plastic, it looks like whoever put the last toilet in has filled the gap?
i think you may struggle to get it flush to the wall
It'll be a challenge, it's hard to say exactly how without having it infront of me, if the toilet unit is deep enough I'd probably use a straight flexi multiquik If not then possibly a long bent one like you have and then use a short straight one as well to push into the bent. (this works) but like I say, it's pretty hard to advise without having it in front of me, you'll probably have to break the collar off too, carefully and ensuring none falls back down the waste itself.
I am here: http://tapatalk.com/map.php?zgun1m
Reply to Newbie toliet fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
Hi, would be extremely grateful for any advice on the following. I'm installing a bathroom (shower, toilet and sink) in my summer house. It has...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
